3 8's again...
sic402
well ive been working on this for a long time trying to get the most out of the compartment i have in my Tundra.. i can fit 3 8"s with aprox 1.2 cu ft, so not much air space, and i could squeeze in 5" mounting depth... i currently have 3 8w3's but i want louder..... 3 8" l7s? would those be much louder, i can get a new amp. and would the 8" Assassins be louder than the jls? i have 500w currently going to the jls. thanks
I could fit 4, but there is not enough airspace for 4 8's cause it would be at about 1.5cu ft, by cutting out a metal divider between the 2 compartments im working with. cant do isobaric because i will have the seat down.
Crystal CMP8s. You will only need 2....400-500 watts each (svc 4 ohm each)
Assassins are louder //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif They dont even NEED over 300, but they can take it
You dont have nearly enough power for the L7s nor the airspace. They should be ported anyways or your wasting your time IMO //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif 166 watts per assassin is pushing it but I think it should still be pretty loud. You could always get a more powerful amp //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
you know i did say i could get a new amp
Sorry I thought you said you wanted to keep your amp. My bad //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif You still dont have the room for L7s. I vote AA assassins and get an amp that does around 1200-1500 at 1 or maybe 2 ohms...
Edit: BTW if you can squeze 1.4-1.5 cubes thats enough of airspace for four...just barely. Just for the sake of having even numbers //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
It's hard to beat a $50 woofer that pounds like the assassin does. I don't think you will find much else in the same price range with the same output.
Yes I have one myself //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
sic402
sic402
Crested Butte, CO
Fast1one
