3 4" areos
bopo668
JerryRig
Would 3 4" areos work for my this set up it will be one 15" type r box will be around 3.5 cubs net with three areos tuned to 32.and the areos will point to the side sub up will that work.or should i go slot forward sub up
Thanks man. Looks like im going with a slot then, not enough area.
You don't need as much area with round ports. The whole reason for having 12^sq.in. per cb.ft. with slot is to minimize as much port noise as you can. With flared aeros, you have a much lower chance of port noise, which is why you don't need as much area.
do some research....
37^2 of flare aero port is about equal to 74^2 of slot.
nice little topic in this subforum too. you should go look it up. heres a hint, it has aero ports and 50% in the title.
bopo668
JerryRig
bopo668
tex
bopo668
vegang
vegang
