3 15" HX2- 2door Blazer box???
well whats the proper cuft each sub should get ported?? approximately.....
atleast 4 cubic ft each... and thats actuall volume, not counting sub and port displacement... im sorry but if your gonna be too stubborn to belive every one then go on and waste your time... but im gonna laugh in your face when someone comes in here and is louder with 2 //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
im not stubborn its just that i want to get the most out of my amp.If i only run 2 of them ill have 2ohm or .5ohm. I have a mmats 2100.1 , will it handle a .5ohm load daily?? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif I hear that alot of people run their hifonics amps at real low ohms??
revrider1 , get the F*CK out of my thread ! you havent been giving any usefull info at all so why even bother making your ignorant comments.
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
i might have jumped in a little late, but i saw it at the top of the recent post list and didnt look at the times of the other posts
I can help give you some great ideas cause i have tried many different set ups in my 2 door jimmy. But like everyone else has said in order to keep the rear seats you will have to use only 2 of the subs.
he says only use 2 of them... my question to that is if i could run my mmats2100.1at .5ohm daily,because at 2ohm theyre not going to be getting that much power???
I am unsure about running the 3 sealed, yeah the guy i got them from was running them in a 7.cuft box but he was pushin them w/ a 3000bd. Im open to using only two of them if i could run my amp at .5 safely so i could get a decent amount of power to them. You know what im saying...wasnttrying to come off as a ***...
Wrong 4 cubes each will be to much for those subs. But yes 2 are the way to go for this setup.
he says only use 2 of them... my question to that is if i could run my mmats2100.1at .5ohm daily,because at 2ohm theyre not going to be getting that much power??? I am unsure about running the 3 sealed, yeah the guy i got them from was running them in a 7.cuft box but he was pushin them w/ a 3000bd. Im open to using only two of them if i could run my amp at .5 safely so i could get a decent amount of power to them. You know what im saying...wasnttrying to come off as a ***...
I would also like to add that i have used the HX2's in my car and have done well with them. Where are you located? I could help you out with this setup and possible give you a box that is taking up space.
GrnZ28
GrnZ28
Chicago,IL
GrnZ28
