3 10's in a 97 S10???
If you use a sealed box you should be able to fit 3 10's behind the seats in an S10. A smaller sealed box will not hit quite as hard as a larger ported or bandbass, but you clearly don't have room for either of those two options. A smaller box will however, give you very clean and punchy bass. You should definitely build the box custom to fit the shape of the cargo space so that you can get the most possible volume in the small spac.
2 things my bestfriend has 4 15" in his 3rd gen s-10 no problem but he has a sport cab. other friend has 8 jl audio 12"s in his s-10 2 are legally door mounted the other six are in the bed, he creatd a "blow through" a space between the cab and the bed where ther is no wall it works great and sounds good
I snuggly fit 3 10"s in the trunk of my old CRX, so hell, i think you can pull it off!
Man did it sound good!, set off 3 car alarms, at vol. 15 out of a 50max setting!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Kighzer
Kighzer
Waycross, Ga
AccordTypeR
Giles
    Sep 4, 2026
Giles
    Sep 4, 2026
