3 10's > 2 15's??
bigandy
so i have had 3 jl w3v3 10's in a 4.3 cube box tuned to 36 and i wanted more so i bought 2 AQ sdc 15's
and i have them in a ported not quite sure on the specs i think tuned around 34hz i think at 7.5 cubes after displacement
they have noth been hooked up to a mb quart dsc 1500.
the jl's are louder to the ear and move almost as air
my ears actually sting after beatin for a while
should i sell the 15's and stick with the 10's or maybe work on a new box since its tuned lower than what aq recomends
by the way jl's are at 1.3 ohm
and AQ 1 ohm
The AQ's should definitely be louder. 2 15's have a good 80% cone area advantage over 3 10's, not to mention I'd expect the AQ's to be more sensitive as well. Something doesn't seem right here...what vehicle is this in? How is it set up?
i was thinking 7.5 wasnt that small really either i know the 4.3 is a little big for the 10's
and its in a trail blazer both are subs up port back
its kinda mind boggling lol
ill try to do a sketch up of the boxes tomorrow for a little more help
7.5ft^3 doesn't seem small at all for a pair of 15's IMO.
oh definitly is. he is obviously talking about spl and he has 3 10s in 4 cubes or so that is much more of a high output box then 7.5 for 2 15s
so comparing these two boxs the 15s have a disadvantage.
but yes you are right 15s can preform in that space.
ok so all the wiring is done right just double checked
the box for the jl's is 45" wide 17"deep 15"high and the port is on the side 4.5"wide and 11.5"deep
the AQ's are 44"wide 18"deep 25"high and the port is 4.5"wide and 12.75" deep with the port going in the middle
both boxes are double baffled at the top and its all 3/4 inch mdf
thanks for all the input everyone
ok so all the wiring is done right just double checked the box for the jl's is 45" wide 17"deep 15"high and the port is on the side 4.5"wide and 11.5"deep
For the JL box I got 4.98ft^3 before displacements, and ended up with ~4.3ft^3 tuned to ~42hz. This is with a 12.75" x 4.5" port that's 11.5" deep.
For the AQ box I got 9.23ft^3 before displacements, and ended up with ~8ft^3 tuned to ~38hz. This is with a 22.75" x 4.5" port that's 12.75" deep.
//content.invisioncic.com/y282845/emoticons/clap.gif.178cba2c538c68e720c727fcb024b19c.gif i knew something was up when the AQ's were sounding waaaaayyyy better than the jl's
so pretty much i have sq woofers in a fart box
i guess ill be going back to the shop that built the box and complaining
thanks alot guys
bigandy
bigandy
ontario, CA
Johnny Law.Lulz
