2x2500D -> 2x12.4?
cyber256
I'm thinking about using my two 2500Ds to power both my 12.4 H2s. Since I already had the subs in dual 4 ohm flavor running 1 amp on each sub would only yield a 2ohm load to the amp (if my math checks out). In my attachment is the wiring diagram for my idea. Would this setup still show a 1ohm load to each amp while delivering ~2500w(max) to each sub?
The manual says that the 600d and 1200d can be strapped but the 2500d can't...
"The Orion 2500d is not designed to work in a bridged or strapped configuration. Attempting to apply these configurations will damage the amplifier and will not be covered under warranty."
Edit: Damm you i3abyjay25, I type too slow... //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
cyber256
cyber256
Frozen Tundra
DBfan187
