These were used for about 1 hour total. Used them to make a 16v setup. They both rest at 2.1v. The marks u see are from glue and paint foam.
Hawker cells use a sealed construction providing long service life, rugged construction, extreme temperature performance, fast recharge, high discharge rates and low internal resistance. Can be added together to get higher voltages and capacities.
- High rate charge and discharge capable
- Extreme temperature performance (-65C to +80C)
- Pure lead-tin construction - low internal resistance
- Long cycle life - up to 1500 charge/recharge cycles
- Rapid charge capable - under 1 hour recharges possible
Specs:
Cell Size: "BC"
Manufacturer: Hawker
Chemistry: SLA
Voltage: 2 Volts
Capacity: 25 Amp Hours
Dimensions: 2.57" L x 6.25" W x 6.82" H
Weight: 58.88 Ounce(s)
$50 shipped or picked up
$30 each shipped or picked up
Specs:
Cell Size: "BC"
Chemistry: SLA
Voltage: 2 Volts
