boostNbeer
Banned
Im adding a second alternator to my car, planning on running it off the a/c belt. What Im stuck on is the rbacket to hold the alt in its place.
I took my 2nd battery and air box out and Ive got tons of room to work with, BUT there are no threaded holes on my block or big bolts that I can make a bracket for the alt off of the engine.
The only solution I could find is that there are tons of mounting bolts and spots on the BODY of the car, so my question is can you have the bracket to hold the alt coming off the car only?? Or will the engine move to much and knock the belt alignment off?
I didnt know if the alt had to be bolted to the engine and independent from the body....
Heres what Im workin with, and my idea, Ive got 5" wide 1/4" thick plate to make this bracket out of
I wanna hold it like this
With a bracket that looks kind like this, welding on the standing pieces also out of 1/4" plate, and on the right side mounting point I will make it slotted so I have some belt adjustment....
Im also unsure of exactly how to get the pulley aligned nicely, you can "eye' it, but Im sure the alignment and angle are pretty **** important. Any tips??
Appreciate any constructive criticism
