I have a mono amplifier currently pushing 1000w at 2ohm to two 12" pioneers,(they are both 1200watts max per sub) and they are 4ohms wired to 2.
I have a second amp that i had a neat little plan for but wanted to make sure i dont screw up anything.
This new amp is a 2/1 channel amp,
Specs:
rms: 185W X 2 (4ohms per channel)
200W X 2 (2ohms " " )
400W X 1 (Bridged, at 4ohms min)
Max: 380W X 2 (4ohm per channel)
1000W X1 (bridged) (4ohm)
So currently I swapped my 2-2ohm subs for 2-4ohm subs both rated rms~400W and max1200W.
the 2-4ohms are in their own shared custom box wired to 2ohms. (pulling max1000W from current amp)
My question (finally): if i swap out my mono amp for the 2/1 channel amp.
This is my plan for wiring;
[(2-4ohm subs wired to 2ohms)in own box] +in parallel [(1-2ohm sub)in own box] = 4ohm total load.
This would then be wired to the 2/1 channel amp as bridged (1000watts max at 4ohms)
[all subs can handle more than 1000watts max.] [mono amp is old and only stable to 2ohms] new amp is only stable to 2ohms per channel or 4ohm bridged.
Would This Work?
Or am i better off another way?
Thank you all for taking the time to read this, its my first post on this forum and i hope all my explanations are at least a little clear.
Specs:
Would This Work?
