28hz?
1.9@28hz should give u a ubber flat responce and sound fantastic
Not Uber flat but will give good SQ at the expense of some output.
I know its against the grain around here, but I like to tune anywhere from 28-32 and sometimes 35hz. Any higher and you get pretty huge peaks in freq. response... good for SPL, not so much for SQ.
Do you listen to metal? With some good drum kicks?
4 15 inch audiopulse axis 15s in yukon xl on one sundown 3500d at .3 subs in 9.5 cubes after dis with 2 6 inch aeros tuned to 26.5 7 batterys and 2 200 amp alts and fully deaden used to burp 39 now 37 since deadning and not a newb worked at 4 shops im waiting on my 2 sundown saz4500s and 4 18 inch nightshades and quad alt bracket and im going with 4 270 amp alts 16 v with 8 batterys to start
i won't tune very far below the FS of the sub, but anything above is doable. a JL W6 would sound great at 28hz, but a kicker cvr 10 probably wouldn't. it's sub dependant, to a point.
dvldogyut
dvldogyut
loretto, tn
PV Audio
