1. You dont have to get that 15 farad cap
2. 4 dual ohm subs can be either 1 ohm or 4ohms
3. HC amps do draw power, D class is always better (for subs)
4. That amp will be fine (if its rated @ 1ohm...)
5. Check out these amps...http://www.thezeb.com/caraudio/audiobahn_specials.html
6. Get either A2200HCX x2 or A1500HCX x2
5. See if you can get any deals on the Audiobahn D class amps...
EDIT: When I say forget about that cap, invest in a few opts, and a HO alt...
Theres not a "better" way to run subs...Its just which way will work, and which one gives me the most power, without going overboard...Opts = Optima Batteries (the best to run with any system, yellow tops are used for car audio...
Now on with D class, I have heard many, ridiculous definitions for class D topologies. I’ve heard people say, of course, that D stands for digital or even that the class is like a report card grade; A is the best type of amp, B is the second best, and so forth. These people must not know that topologies go far beyond the F grade... Actually, D just means 4. A was the first type of amp recognized by the IEEE, a group of professional electronic engineers. B was second, C was third, D was fourth, blah blah blah blah... Truth is, there is no such thing as a digital amplifier! If digital information is written in 1s and 0s, then what would a digital amp do? That’s right, make big ones and zeros ; )
Class D technology is growing in the 12 Volt industry. There are a few companies producing these amps and I suspect a few more companies will jump on the wagon for good reasons. The main reason is for dramatically increased efficiency. This is done by "Switching" and is therefore a "switching amplifier" as compared to a non-switching amplifier like a class A amplifier.
A class D amp can be more than 80% efficient while a Class A/B (which most amps are) will fall into the 50-60% range. Let’s say we have two identical vehicles and we are going to put a class A/B sub amp into one of the vehicles and a class D into the other. Both amps, for comparison put out 1,000 watts RMS with 12 Volts. The vehicle with the class A/B amp will draw approximately 160 amperes of current and , being 50% efficient, will put out 1,000 watts of heat into the heat sink! Bummer, huh! The class D amp will only draw around 98 amperes to yield the same 1,000 watts RMS output. Not only will your vehicle like you better for not draining the power supply, but the amp will like you better as well because now you will only produce about 175 watts of heat into the class D heatsink! For you tweakers, that’s 40% less current draw and 82% less heat for the heatsink dissipate...
Class D is great for bigger sub amps only as the benefits do not outweigh the cost for a smaller amp. So, why don't people make a class D amp to play 20Hz to 20kHz?! Not a simple answer, but here goes... The audio signal is used to modulate the shape of the square-looking waves of high frequencies. Then the high frequencies are eliminated, leaving audio output. The type of modulation used is called Pulse-width Modulation, or PWM. PWM, like the power supply in many car audio amps is used. Truth is, a PWM power supply as an amp that has DC output only. If you want to play 20kHz you would have to have the output devices switch at hundreds of kHz which almost reaches the AM radio frequencies. You see, the Pulse Width Modulated (PWM) wave frequency must be a lot higher than the desired playing frequency. To play 500Hz, we only need to switch at a frequency around 60kHz.
In summation, class D amps put out more power and less heat with less current consumption. But as for now, they are only beneficial as larger subwoofer amplifiers.
sk8
sk8
Denver, CO
sk8
