Not everyone uses a bolt... And if you insist on a bigger hole, why not get a drill bit? Then it can be any size you want. My asking price comes out to 60 cents each, I'd say that's a deal.what sort of bolt are you suposed to fit through that 1 cm hole...
Even standard 1/0 crimp terminals have to be drilled out. I had to drill out ALL of my gold-plated fancy pants car audio ring terminal for the ALL 3/8" bolts I was using.what sort of bolt are you suposed to fit through that 1 cm hole...
Which is crazy sense isnt that what kinetik batteries use?Even standard 1/0 crimp terminals have to be drilled out. I had to drill out ALL of my gold-plated fancy pants car audio ring terminal for the ALL 3/8" bolts I was using.
//content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
nG
