2012 Chrysler 200 upgrade (2 PSI 12s on a AQ2200)
Ronoman
Hey everyone! This will be the second build in my Chrysler 200 and I figured since this was an upper level install I would make a build log. Basically I'm switching from 4awg to 1/0awg, upgrading my alt/batteries, and switching to an AQ2200. To start I'm gonna upload some pictures of the new gear I opened today and then tomorrow I will upload pictures of my current build before I rip everything apart.
Current Build:
2 PSI Platform 1s in a 4.0cuft box built by Brian Horton
Alpine MRX1100
Rockford P400X4
Incriminator Components
Rockford Power 6x9s
Pioneer 5500BHS
Update:
AQ 2200
NVX Sound Deadener
NVX 1/0
Singer 350a Alternator
D1200 in the back
NVX 1/0, NVX 8awg(speaker wire), and fuse blocks.
350a Singer alt
D1200 battery
NVX Sound dampening stuff
And lastly, the beautiful AQ 2200D
Here is my current setup!! I plan on flipping my box around 180 degrees to have it fire inside the cabin, because I am afraid of my trunk actually falling off. I'll be making a small piece of wood to seal the front of the box from the trunk.
Pioneer Headunit
Alpine 1100MRX and Rockford P400X4
2 PSI 12s
D975 battery (Will be moved to front)
Incriminator Tweeter
Put the subs 6-7 inches away from the rear. It will give you the best results. I have the same car.
My trunk moves WAY too much already, I don't want them any closer! My trunk doesn't close right anymore with them that far away.
Update from the last few days. I got decently far into ripping out my QuickRoof and installing the NVX sound dampening. My goal for tomorrow is to have my MDF and foam cut for the battery/fuse mount and the amp mount.
This is my trunk all ripped apart
Installing a system in my friends new Acura
Wired my box down to 0.5ohm with the NVX 8AWG
Today I got some good stuff
This is weather stripping foam stuff that I will be lining the bottom of my rear deck with, so when it bounces it doesnt make as much noise.
Here is how I will be mounting my sub amp.(The black washers are rubber) the middle nylon spacers is representing where the amp will be.
Lastly.. here is the foam that will be between the mdf/amp and sub box.
Sorry for the crappy phone pictures, but its all I had at my friends garage. So the alternator I ordered had the wrong case on it. But we installed most of the 1/0. Some time this week I will be installing the rear battery so it can be charged in my car for a week or so before I finish everything. Today I also ordered 5 more feet of 1/0.
Soldering the ring terminals
Some engine bay shots
My D975 in the front
Turns out Singer sent me the wrong alternator case.. So he is making a new one now.. tomorrow I plan on finishing everything so then when the new alt comes I can just install that and be 100% done with everything. I need help with the 'big 3' I cannot find an engine block ground!!
Just ground it to the alt case bolt
Ronoman
Ronoman
Minnesota
NASTY08IMPALA
