badstang123
I have a 2008 Avalanche with the components in my sig. Upon original install I had a small (And I mean very small) amount of engine whine. After about a month I suddenly got extremely bad engine whine and had strange continuity problems with my rca's. No continuity with ground, continuity with power, etc. In addition, the left channel would play at low volumes and my amp started making a burning smell. I exchanged the unit with Sonic Electronics. They gave me a brand new unit (Yes I'm positive they did because the General Manager is a good friend) I installed the new unit and was back to my very small amount of engine whine.
After my second drive in the car the excessive whine came back (This problem will come and go. When it does go away, which is seldom, it will normally come back after playing the radio at high volumes). In addition there is a a small crackle or fluttering type noise from the front passenger tweeter. I checked continuity again and everything is fine. In addition, when I disconnect the RCA's from the amps the noise goes away. I proceeded to ground the RCA's to the head unit chassis externally as many do on the pioneers, I disconnected the antenna, gps antenna, mic, and steering wheel controls individually to see if any of those things were introducing noise. I also added an additional headunit to chassis ground so the unit would have a better and extra ground. All of these changes have produced zero progress to remedy the problem.
I need some new ideas as to what the problem may be and what to check. I am now considering the scosche onstar lan unit (which I cannot disconnect because it is where the factory harness provides power to the headunit and ties in) and also am considering the relay near the unit (Since the onstar unit is on at all times I have a relay between it and the head unit so the headunit does not stay on at all times. The unit could be it again but with the same symptoms I'm kind of doubting that. Anybody have any other ideas?.
I have also checked every power, ground, and other connection possible on amps and the head unit. And if it's in any sticky or thread in regard to engine whine I have probably tried it. But I'm open to any new ideas. If you guys have any other ideas or experience with something like this please help. I'm ready to kill myself //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gif
Thanks
- Justin -
Thanks
- Justin -
