2004 lincoln navigator wiring help.
SPL KID
2004 navigator
where are the vss wire, power lock/unlock wires, also how do you get the factory amp to work with aftermarket headunit please?
colors and locations of wires if possible . Have a remote start and Nav unit to install in one that had factory Nav and contains a amplifier. 4 plugs on back of old unit.
well so far i bypassed the plugs but the amp sounds like it stays on when the remote power is off from the deck. I can still hear dead air from the tweets....
The reason it stay on is because the factory amp turn on/off wire is located in the harnes that you bypassed. You need to purcahes a GMOS harrness. I believ it will be the GMOS 04 harness. It will take care of all that for you. Are you alos installing an alarm with keyless entry, or a keyless entry system, or remote start with keyless entry and or alarm?
SPL KID
SPL KID
Raleigh, NC
SPL KID
