2004 Jeep Liberty Big 3 Done w/ Pics!
Kriszilla
Skydiving is life
I'm slowly but surely getting my system back together. I'm currently working on flush-mounting a RF 25-to-Life edition Punch 75 and an RF T10001BD into the tailgate of my Jeep. But I also need to upgrade the power...
To that end, I ditched the stock battery and picked up an Exide Orbital Select G34/78 sealed batt and did the Big-3 using the new Knu triple 1/0 battery terminals and some JL & Stinger 1/0 cable.
First, we have the new battery and its new cabling:
Next, in this pic of my alt, you can see where I added a 1/0 run to the stock 8 gauge run and where I added the engine ground via the alternator bracket bolt.
Here's the view from above with labels. I probably didn't need to reinforce the wiring to the factory fusebox, but I went ahead and ran a length of additional 4 gauge wire to it just to be safe. You can also see the frame ground in the bottom of the pic. That piece is a direct weld to the Jeep frame. I used a dremel to clear the paint and used a stainless steel fender washer and self tapping screw to attach the run of 1/0.
After all is said & done, there has been a big improvement. Before, I could never maintain a voltage higher than 13.3 at the amps, and whenever I used the power windows, the headlights would noticibly dim as well. After the upgrades, I'm holding at 14.3 volts at the back and there is zero dimming. //content.invisioncic.com/y282845/emoticons/cool.gif.3bcaf8f141236c00f8044d07150e34f7.gif
nice I like the heat shrink,I think it looks more professional.Do those battery post accept 3 seperate 1/0ga wires or is it just 2 and a spot for 4ga.?
Thanks. The posts accept up to 3 1/0 cables, but they each come with one 4ga compression fitting that you can swap for one of the 1/0's as well.
where is the wall //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
//content.invisioncic.com/y282845/emoticons/uhoh.gif.c07307dd22ee7e63e22fc8e9c614d1fd.gif
Not all of us are as insane as you, Dan.//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I've got my first kid coming in January and the wife has put her foot down on space. This is why I'm integrating my amps into the tailgate and why I'll be doing a single 12" FI-Q w/ BP option sealed. But I'm going to be putting cose to 1500 RMS on that bad boy so I think it'll help make up for the lack of a port.
Kriszilla
Skydiving is life
Kriszilla
NE Tennessee
audiobahnuser18
