2003 VW Jetta - Removing HU and door panels?
frim what ive seen the design in the 2003's is the saem as the later 99gen. just put your hand inside the empty pocket/dinspace and give the plastic molding a yank, it should pop right out. however doing this on a passat can be very difficult....but all the golfs/jettas ive worked on this dinspace-pocket thing popped right out with a small yank
fomr there- your gonna need thin pieces of metal to put in the thin slots by the seek/tune rocker buttons......you should be able to wiggle it out then...good luck.....sometimes it pops right out..other times it can take a good 20mins or so of plain around if u dont have perfect tools and all..
hope i helped
-pat
You will need a specific set of european keys to (properly) get the stock HU out.
Not sure about the door panels..I have done them before, but its been a while. The only thing i remember is if there is some woodgrain on the handles, there are a couple screws under it.
Horizons
Horizons
Orange County, CA
crhye250r
