2002 Trailblazer headunit install problems.
Gearstix
My buddy installed a head unit in a 2002 Trailblazer, and is having some problems.
Here's what he says.
i have the wiring harness from walmart, for an '02 trail blazer. Hooked everything us as it should be. The CD played gets power, but will not come on. The reset light does flash, but resetting it does not do anything. i know for a fact the CD player is good.
The stock radio can be plugged in and will work perfectly, but i cannot get anything out of the aftermarket
Should he get a 'pac module' or similar?
Sounds like it may have something to do with the harness...is he using the OEM harness or did he get a harness that will allow the addition of an aftermarket radio? I have a Silverado ('08) and you need either a harness from Axxes and one from PAC (for the steering wheel controls) or, after going that route and calling PAC about a question, I discovered that they have a harness that will handle both the HU and the steering wheel. Of course, your buddies is an '02 so it may not be that complicated. //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
i think my friend had the same problem in his 04 Envoy. i think the harness was no good. so we just ran new wires.
Gearstix
Gearstix
Alberta, Canada
dropped_tb
