main question!!! one thing I would ask the person/company making the alt is:
what is the output at IDLE!!!
Different companies make the same 200 amp alt...but some companies require 3000rpm to get the full 200 amps. A 200 amp alt that only does 80 amps at idle is basically useless when you're in traffic, stop lights, parked...what ever (with those alts, if ANY damage is ever done, most likely that's when it would be, at idle).
It might cost you a little extra money but well worth it. Def. worth asking.
Any respectable company would have no problem giving you a demo of the load test of their alts. They should show you different outputs at different rpm's plus the true load test to prove the maximum output.
