20-pin ATX connector for speakers?
GCAdidas13
heh.
I'm trying to create my amprack such that when I need to move it, three connections can be removed and the amprack will come out.
(don't worry about it making theft easier... the bolts for this amprack will be well hidden.)
Would it be okay to use an ATX connector:
(after removing all wires and soldering to the actual pins inside of the plastic connectors)
to make all of my connections?
Basically will the connector pins create too much resistance/whatever to cause problems?
THX
Brian
I was seriously considering doing my 0 gauge, but i'm running
(2) PPI PCX2200
(1) PPI PCX4125
(1) PPI PCX440
so I think I'll be pushing somewhere around 300a as it is.
I've already ordered the ATX extender displayed above...
I will need to use 19 of these pins
Tweet +/- for L/R
Midrange +/- for L/R
Koda +/- for L/R
Subs +/- for two subs
One for remote wire
Two for fan +/-
And again, with the wire soldered directly to the pins inside of the plastic connectors, will that connector cause any problems?
Also I couldn't find any multiple-connection Powerpoles, Jack Frost.
Thanks
Brian
brian, we use those 20pin molex's at curcuit city, they are used by METRA and they are used in the 'smartharness'. basically its a line of harnesses that have a vehicle->female 20ping, and HU->male 20pin.
what you can do, is cut that connector in half, strip, and solder to all your wires. use heatshrink - do NOT try and remove all the pins and re-do them. it will be a pain in the ***.
just cut the thing down the center, strip about 1\2" of insulation, insert into heatshrink, twist, solder, snip, and heat the heatshrink. do this to all the wires and you will then just be able to plug the two 20-pins together, and all your wire issues for the speakers will be done.
but you are going to want to use them big 4awg-0awg breakaway connectors for the power\ground. but as far as speaker\remotewire goes, that ATX connector is a great idea IMO.
GCAdidas13
heh.
GCAdidas13
Grove City, OH
GCAdidas13
