I talked to US Amps today and the MD3 will be out at the end of next month.have they released the MD3 yet?
I Say Collossus Because It Does Plenty Of Power For Those L7's,and You Ca Run It At 2 Ohms,the 20.1 I Heard Is A Awesome Amp,but If U Run It At Half Ohm,that Means Alot Of Current Draw,anytime U Run A Amp Below Its Rated Ohm Load,it Takes Alot More Power To Feed It
Why don't you like the XX series, my colossus puts out 600 more watts than it's rated at. Hifonics XX are very solid amps.ive alway heard bad things about hifonics, most of there amps don't do rated power, i don't know if the xx does or not but the lower end doesn't
PROBLY BECAUSE YOU CAN SET THE GAINS MUCH EASIER STRAPPEDif you strap the ia's at 2 ohm, why wouldn't you just run them at 1 ohm each?
