2 XXXs?
bamaboy
War Eagle!!!
i really dont know waht i want but to try and figure it out how about 2 XXX 15s and 2 a3000s, i can get the stuff i just dont know if i want to give up the box space im thinking 8 cu ft @ 33hz
Net Volume: 8 cubic feet
Tuning Frequency: 33 Hz
Port Width: 5.5 inches
Port Area: 96.25 Square Inches
Port Length: 21.75 inches
External Dimensions: 36 wide x 19 tall x 28.75 deep.
Board Dimensions and Quantity
Color Count Width Height
Top and Bottom 2 36 inches 28.75 inches
Red 1 29.75 inches 17.5 inches
Yellow 1 28 inches 17.5 inches
Black 1 34.5 inches 17.5 inches
Green 1 28.75 inches 17.5 inches
Teal 1 18.25 inches 17.5 inches
Number of 49x97 Sheets of 3/4" MDF: 0.9375
what should i change on it i cant do any more than 29" deep i really dont want to do that, i think im gonna make it taller and wider but like 37x20x27 or something like that
Net Volume: 8.2 cubic feet
Port Width: 5.25 inches
Port Area: 91.875 Square Inches
Port Length: 19.75 inches
External Dimensions: 37 wide x 19 tall x 28.75 deep.
Top and Bottom 2 37 inches 28.75 inches
Red 1 31 inches 17.5 inches
Black 1 35.5 inches 17.5 inches
Teal 1 16.5 inches 17.5 inches
Number of 49x97 Sheets of 3/4" MDF: 1
and i dont even know if the 2 15s would fit on the box
here is how they would have to go
37" wide and the port in each one is about 5.5 so 32" to mount 2 15s that should be enough, i want to mount them like the first becasue when i point subs at my hatch thing it rattles like twice as much and when they point at the roof it takes the rattles away for the most part and is still pretty much as loud
there is this way and how do you make a crx box ?/it would be easier to fit 2 15s i would believe
no, its a vid off realm
i dont have a video camera and my olympus digi sucks at video, which i dont understand because it was like 500$ //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
my sisters canon power shot digi cam is alright for vids, my sony handycam is def better, but thats what it was made for, but i lost the software //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
you could mount both on top, and the port either across the top or side, but on the longest side.
the proposed 36/37" side is where i would put the port, either exiting on the top with the XXXs or sides.
So your port would be like 34.5"-35.5" x X" - whatever will give u 33hz
Why would you have to give up space? 8cuft is fine.
If they share the same chamber, then i think u could get away with even 6cuft the least.
This confuses me. Why would sharing the same air space as another sub decrease the necessary volume from 4 cuft each to 3? If anything, Id go bigger than the recommended 4 cubes per that RE recommends. I know when I port my xxx 15's, Im expecting to use 8-10 cubes, plus port displacement.
I have my 15's in 7 cubes net. I'm happy with it. If you can't be satisifed with 2 15" xxx's in any box, there's something wrong with you //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
EWWW you're using accelerator pedal!
it was just to get a quick idea of how ig the box will have to be, and what is wrong with it? //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
bamaboy
War Eagle!!!
bamaboy
Auburn, Alabama
bamaboy
