2 x Digital Designs M2B Amps F/S
  • 2
72Impala
1. Product:
2 x DD Audio M2b amplifiers
2. Specs:
Cont Power at 1 Ohm 1,700W x 1ch @ 12v, 2,400W x 1ch @ 14.v
Damping Factor NA
Dimensions (US) 19.75" x 6.9" x 2.03"
Dimensions (Metric) 50.17 x 17.53" x 5.16 cm
Dynamic Power 3500 x 1
Efficiency Thru Output 87%
Input Sensitivity 8V - 0.2V
Shipping Weight 15 lbs / 6.8 kg
Wire Gauge (Power and Ground) 0 AWG
Wire Gauge (Speaker Output) 10 AWG
3. Description/Condition:
Used. These are in good shape. Couple minor scratches here or there. Work perfectly. Each amp is missing 1 set screw for the speaker outputs but that is easy and cheap to replace. Also not even needed. I got them off a guy semi locally that is a competitor. He is known to take care of his stuff. These were ran in conjunction with 2 x DD9512J subs.
4. Price: :
$400 shipped per amplifier. $775 shipped for both
5. Pictures:
I used to have a pair of dd audio redline 608s, for eight inch subs they were very impressive, at least until that ole upgrade bug bit anyway. I...
4K
I use K3b to rip cds and for converting to any file extension I use Sound Converter or Soundkonverter on a Linux machine but you should be able to...
15
That makes sense. I took it apart today. It doesn't look too impressive but it should be better than the head unit. I'm going to install something...
72Impala
72Impala
Clarksville, TN
72Impala
