2 Warden 18"s walled on 5kws
slam
So, I decided to install a couple of subs that I have laying around. Picked a wall and started cutting some holes.
Had to take the frame out the wall.. Really wasnt too hard to do
Made a 5 layer baffle,1 counter sunk, and mounted it the 2 studs and other heavy brackets for weight and impact. Puttied the holes, sanded the roughness, and painted the area
built a shelf for 4 qsc 2450 amps and other audio gears. Still working on the area and installing other equipment. Framed the hole and stained the wood to match the floors
Installed the subs. Like i said they were laying around lol
Ran speaker wire thru the walls and ceiling for the front stage
This setup gets down on the lows and surprisingly sounds pretty **** good for some wardens.
slam
slam
fort worth, tx
keep_hope_alive
