2 SA12s vs 3 E12s
So I am looking to upgrade my setup. Im mainly looking for spl. I bought a Sundown Audio 1200D amp recently, this works at 1 ohms. I have been trying to decide what drivers to buy. I have limited trunk space(32"x16"x24). In my budget I can afford either 2 SA12s, run 1200 to them both at 1 ohm as they are 600 rms each, in a ported box tuned to manufacturer Rec. or I could get 3 E12s But my worry is that I would not have enough space to make the box vented. If I could make it vented, what size port area would I need for these 3 tuned at 35 hz? I can't figure it out based on online research and I run a mac, so I can't download programs. Would it be under 6.5 cubic feet or so for all 3 vented?
So my main question is- which would have more spl, 2 vented 12" Sa12s or 3 sealed E12s? Or 3 vented e12s if space allowed?
I'm building my first box for a final project for a class I have, so I have access to table saws, etc about everything I need. Don't think there is a router, so I would have to use a jigsaw to cut out hole.
If this helps:
SA12 D2
Re: 4.57 ohms
Fs: 33.71 Hz
VAS: 21.21 L
Qes: 0.58
Qms: 5.34
Qts: 0.52
Le: 3.40 mH
BL: 21.64 NA
Mms: 280 g
Sens: 83.21
RMS: 600 Watts
E12 D2
RE: 3.8ohm
Fs: 35.8 hz
Qes: 0.56
Qms: 6.79
Qts: 0.52
Le: 1.85mH
Vas: 47.6L
BL: 15.4NA
Cms: 0.13MM/N
Mms: 156.6grams
Sens: n/a 1w/1m
Xmax: 12mm one-way linear
RMS: 400 watts
Thanks for the help yall! Any questions feel free to ask!
On Sundown's website, the E-12 calls for 1.5-2.0 cubes (ported). So giving them 1.5 cubes, 3 would take up roughly 4.5 cubes (plus port area). You could fit them.
So how much porting area should I have? thats what I can't figure out. When I put the T/S specs into a port/box builder it says I need 3.8ish ft^3 per box and a large port. then i put in port calculator with 1.5 ft^3 and it says I need like 60 inch deep port. maybe im screwing this up?
Also, would they be all in the same 4.5-5 ft^3 area or would I partition off a 1.5 cubic foot area? Am I making this a lot more difficult than it needs to be? I just wanna make sure I do it well and I'll be working on it for a few weeks so I'm gonna take my time definitely. Thanks for help!
The way i was thinking if i made it with 3 I would make two trapezoidal on the side that angle out towards bumper and a square in the middle. Like this
________________
|......._______.......|
^not final draft hahaa
Bassorback
Bassorback
Fayetteville ar
KyleBechtold
