Sold 2 Re 10s 2 Alpine 10s Fs No Trades
jonesy
1. Product: Re audio Re subs
2. Specs: Re Audio specs
* 10"
* 175w RMS (600-800 watts peak)
* Dual 4 ohm voice coil
* Mounting Depth - 5"
* Mounting Hole Diameter - 9.125"
* Overall Diameter - 10.125"
* Bolt Hole Circle - 9.75"
* Motor Width - 4.875"
* Motor Depth - 1.5"
* Basket Depth - 3.5"
* Displacement - 0.09 cu. ft.
* Weight - 6.5 lbs.
* Mica Filled Poly Cone
* Santoprene Rubber Surround
* Pressed Steel Basket
* High Temp 8-layer Copper Voice Coil• FEA Optimized Motor Structure
* Single Magnet
* Linear Conex Spiders
* Foam Gasket
* Sealed Box Dimensions: .35 - .5 cubic feet
* Ported Box Dimensions: .65 @ 35 HZ - 1.0 @ 35 HZ
* Electrical Q Value -Qes: 0.39
* Mechanical Q Value -Qms: 4.37
* Total Speaker Q Value -Qts: 0.36
* Free Air Resonance -Fs: 21.5 Hz
* Equivalent Compliance -Vas: 75.6 liters
* One-Way, Linear Excursion -Xmax: 12 mm
* Efficiency -SPL 1W/1m: 84.7 dB SPL
* Effective Piston Area -Sd: 322 cm^2
3. Description/Condition:
New BNIB
4. Price: :$100shipped pair
5. Pictures:
jonesy
jonesy
Castletion Ny
loudrango
