2 q's
If the cigarette lighter is controlled by the key switch, then there's no reason you can't use it for amp turn-on; but I'd tap the wires behind the lighter socket instead of using a plug. Yes, you can daisy-chain the wire from the first amp to the second amp. There would be no need for a relay.
Dont be lazy and either 1. Het a new HU, or 2. Find an aftermarket harness for your HU....running it off the cig lighter is a little ghetto :p
Lazy is the least of my worries, 1) The HU I want costs $2K DVD/Navigation/30Gig HD, Not a flip out screen...This is not exactly pocket change. 2) Never thought of it as an option...Kudos
tap into power antenna, or run a switch if you want to be ghetto? although i like switches sometimes.
If I was to tap into the power anttena then the amps would only power up when the HU was in Radio. So thats not going to work since i would rather listen to 1 cd (mixed by me) continously than the radio. The switch would still need a 12V to come from somewhere.
A last the answer I have been waiting for, No realy and daisy-chain is good.. As for the cigaret lighted, well i just tapped into the wire in the back, i wasn't planing on useing a plug.
Will post pictures of the install later on today, I worked on it from about 9am to 3pm... Probably slow for some people but since i was working on it on the side of my building I was very conservivavly removing panalind and sealts, etc.... Don't need the goods stolen.
Dj-torn
Still learning...
Dj-torn
Fairchild, WA
Dj-torn
