2 orion hcca 2400d?
kinda new. if i strap two of these orion hcca 2400d together how much power do i get from them at 1ohm 2 ohm and 4ohm?
spec.
1x425 4 ohm
1x800 2 ohm
1x1200 1 ohm
2400 max.
to strap at 1 ohm, both amps would have to see a 0.5 ohm load which is not recommended. If you strap at 2 ohms( 1 ohm each) you'll get 2400 watts and at 4ohms( 2ohms each) strapped you'll get 1600 watts.
edit: i can see i'm a little bit slow on the response
thing thing is when straping them, i dont get the speaker wiring set up part. im trying to wire up 2 eclipse dvc 4ohm. how can i wire them them to 2ohm or 4ohm. i was told something about connect master amp pos together and slave amp neg together. but how would i wire 2 sub. i only see diagram of 1 sub wire.
when its strap it not 1ohm but can i still run it at 1ohm? my sub are dvc 4ohm and i cant run it at 2ohm, only 4 or 1 ohm. i have two subs..
smiley2186
smiley2186
San Diego, CA
smiley2186
