Sold 2 Minty Soundstream Van Gogh 4 channels and 2 Battery's
dave_damage
Soundstream Nut Swinger
Here I have 2 almost brand new Rare Soundstream Van Gogh Class A/B 4channel 320.4's These have no marks on them at all. As close to new as you will find. If you know this line you will know it is a rather under rated amp. Looking for $250.00 each or $450.00 for the pair.
# 4 X 80 RMS 4 Ohm
# 4 X 160 RMS 2 Ohm
# 2 X 320 RMS 4 Ohm
# RUBI™ (Rapid-Use Branched Impulse) Proprietary power supply topology
# STACT™ (STabilized Apex Current Topology) Reduces power supply stress by 50%
# Trident™ Amplifier protection topology
# Ultra Low ESR Capacitance bank ensures rapid power delivery for dynamic peaks
# Continuously variable 12dB low-pass crossover (30Hz to 4kHz)
# IDI™ (Intelligent Distress Indicator) gives visual amplifier protection status
# Triple Darlington OUtput Circuitry
# Continuously variable high and low pass crossovers with 12 dB / Octave slope (30-4KHz)
# Vortex induction fan for thermal management
# Platinum RCA Line inputs and outputs
# Platinum 4 gauge power inputs
# Rail stabilization protection circuitry
# Tri-mode operation
# BIP™ Bias Input Protection
# Harmonic Bass Alignment™ Produces tighter, more accurate bass reproduction
# Bi-Linear selectable 2 way crossovers for amplifiers and line outs
# 10Hz - 50 KHz Frequency response
# >115dB S/N ratio
# >500 Damping
# .15V - 12.0V Input sensitivity
# 0.02% THD
# Dimensions Dimensions Dimensions 13.8" L X 2.6" H X 11.2" W
2nd I have to battery's I got off here in hopes to put in my Grand Am but even tho they are small, they don't quite fit ware i wanted to put them. I just want to get what I got in them back. They sit at 12.9 and 12.8 Seem to be just like the BatCap 800's. Looking for $45.00 shipped each or $75.00 for the pair.
are these amps better than the tarantula line?
All depends what tarantula line you are talking about. If its the TR line from 02-04(Huge all Chrome with the handles) they are on the same level. If you are talking about the ones after those, yes these are a lot better.
dave_damage
dave_damage
Gary, Indiana
dave_damage
