2 Memphis MOJO 16-MCD4KW's
Jayzbent
IlliNOISE
2 Memphis Mojo 4kw's 1st one is in pretty mint condition 9/10 cosmetic 10/10 mechanical. 2nd one is a older one. It has some scraps on the end. And has some light scuff marks on it. Could probably be buffed out. 7/10 cosmetic 10/10 mechanical. No bass knob or fuse holder.
SPECIFICATIONS:
MOJO Series Monoblock Class D 4000W Max Amplifer
RMS Power Rating:
4 ohms: 1000 watts x 1 channel
2 ohms: 2000 watts x 1 channel
1 ohm: 4000 watts x 1 channel
Max power output: 4000 watts x 1 channel
Total Harmonic Distortion:
4 ohms: 0.5%
2 ohms: 0.75%
1 ohm: 1.0%
MOSFET power supply
Remote bass level input (remote level control sold separately)
Power, protection and blown fuse LED indicators
Custom black pearl finish
Signal To Noise Ratio: 95 dB
Input Sensitivity: 250mV - 9V
Input Impedance: 22Kohm
Damping Factor: >50
Output Impedance: 1-4Ohm
Low heat generation
Gold-plated RCA inputs
Buffered RCA low level output (loop through)
Variable low-pass filter (50-250 Hz, 18 dB/octave)
Variable high pass subsonic filter (20-50 18dB/octave)
CEA-2006 compliant amplifier
Dimensions: 31-1/2"L x 7-5/8"W x 2-1/2"H
$600 shipped newer one/ $500 shipped older one. Or $1050 shipped for pair.
On me
Kitty Approved!
Newer One
Jayzbent
IlliNOISE
Jayzbent
Columbia, IL.
force16969
