SOLD 2 kicker SX900.4 digital amps
slapmaster
mobile al
both used and have light scratches and work 100%
one comes with end caps and original box. no birth sheets for ether
180.00 shipped each. first to buy gets the end caps and box.
The 04' Kicker SX900.4 four channel amplifier will complete your system with a look no one else will have. This amp can put out an amazing 900 watts of power but that is only the beginning. The whole SX series features a digital signal processor that will allow you to tweak this amp precisely how you need it to get the best sound from your system! You won't find a better amp at this price, own one today you won't be disappointed. Kicker a trusted name in car audio!
Brand: Kicker
Condition: used
RMS Power Output: 113W x 4 @ 4 Ohms
Peak Power Output: 226W x 4 @ 4 Ohms
Birdged Output: 450W x 2 @ 4 Ohms
Signal To Noise Ratio: 100dB
Frequency Response: 20-20,000Hz
Bass Boost: 0-18dB
Built-In Crossovers: High and Low
Low Level Input: No
Built in Cooling Fan: Yes
Bass Control Knob: No
Dimensions: 25-3/4" L x 10" W x 2-1/2" H
please excuse the mess of wires, i had to whip it together just to show they work.//content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
Bumpage for 2 good amps. If they're not sold by next Friday then they'll be mine. If anyone does get one of these it will be well worth getting the SXRC to control them from your dash or wherever you put it
Looks like this. Bad pic but you can still see it good enough
840
slapmaster
slapmaster
mobile al
slapmaster
