SOLD 2 kicker kx600.1's
do you mean 8 ohms, the w6 is dual 4 iirc, these strapped at 8 ohms would produce 600 watts. that would be ok for the w6
you cant wire a dual voice coil 4 ohm subwoofer to 4 ohms. only 2 or 8 ohms. 600 watts wouldn't do any harm to a w6, just make sure and set the gains moderately.
BUMP
929
Fission
Hello. Hello. Hello.
Fission
Midwest
Fission
Decebal
    Jun 10, 2024
