2 kcker cvr10's on RF T500-1bd???
SilverBullet6.0
I have 2 kicker CVR 10 4ohm DVC subs. I just bought a Rockford Fosgate Power T500-1BD mono amp. My amp's birth sheet say it makes 750 watts rms at 1ohm. So I plan to wire my subs in all parallel for a 1ohm load. My box has the lil spring terminals on the outside to run the wire to the subs inside. I should be able to run wire from the amp to one terminal, then wire from that terminal to the other, right? The sub's voice coils are already wired parallel in the box.
I was just reading the manual to this amp, and although its a mono amp it has 2 outputs, A and B. My amps manual says these outputs are wired in parallel to the same source. So, I'm thinking if I wire 1 2ohm load sub to each output, the actual amp would see a 1ohm load and put out the full 750 its capable of. Am I correct?
Yes Sir, you are correct.
SilverBullet6.0
SilverBullet6.0
Malden, MO
SilverBullet6.0
