Sold 2 jl 10w3 and Helix A4 competition
matdotcom2000
I have two jl 10w3 subs that are used that I am looking to get 110 obo shipped for each. If u have a tundra in houston I have a box to go with them for an addition 50.
I also have my helix A4 back up for sale that I am letting go for 450 shipped OBO (or best offer) IN THE USA great amp BTW... VERYYYY powerful dont let the specs fool you.
Helis A4 consider by some to be better than the DLS A4
I bought it used. BUT this amp new is Over 1000.... Its a baby Brax.....
Specs
# Cont. power rating RMS/Max. power at 4 Ohms RMS/12 V: 4 x 60/85 Watt
# Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V: 4 x 85/160 Watt
# Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V: 4 x 153/300 Watt
# Cont. power rating RMS/Max. power at 4 Ohms RMS/13,8 V bridged: 2 x 270/450 Watt
# Cont. power rating RMS/Max. power at 2 Ohms RMS/13,8 V bridged: 2 x 395/650 Watt
# Total harmonic distortion:
# Signal to noise ratio: > 100 dB
# Damping factor: > 450
# Frequeny range: 20 Hz -20 kHz
# TIM distortion:
# Input sensitivity: 500 mV - 8 V
# Fuse: 3 x 25 A
# Input impedance: 10 kOhm
# Bassboost adjustable channel C und D: 0 - 9 dB
# Dimensions (HxWxD) mm: 35 x 240 x 432
# Weight net: 4,7 kg
# Driver with class A technology
# Outputstage with 24 MosFet transistors
# RMI (realmixed input) for forming an optimised mono-summation signal from the left and right channels
# NFI (noisefree input) for distortion-free listening
# Intelligent active crossover
# Bass Boost Control 0-9 dB, adjustable center frequencies 30-120 Hz
# Mono/Bridged/ Stereo switch
# 8.0 volt input for connection to any signal source
# ADC - Anti Distortion Choke to eliminate distortions
# Intelligent temperature and power controlled switching power supply
# Separate speaker protection circuit with current limitation for speaker short-circuiting, cable contact with car chassis, low impedance and wrong connection
# CPS - Color Protection System
# SMD - Surface Mounting Devices for constant assembling quality
# Double-sided, extra strong (2x 110u) and copper plated pc-board for best power and signal transmission and protection against vibrations
# 24-karat gold-plated solid connectors suitable for 25 m²/ gauge 4 cables
# Temperature-optimised heatsink for highest efficiency
# 1% accurate components for perfect audiophile sound quality and maximum power
Here is a review list of the Helix against the competition. From a foreign car audio magazine
* Audison VRx 4.300 CS2 (29/30; 1485 Euro) - [4x116 @ 4ohm]
* Audison VRx 6.420 CS2 (29/30; 1745 Euro) - [4x77 + 2x99 @ 4ohm]
* Steg Master Stroke Classe A (29/30; 1900 Euro) - [2x119 @ 4ohm]
* Brax X2400.2 Graphic Edition (29/30; 2300 Euro) - [4x148 @ 4ohm]
* Helix A2 Competition (27/30; 660 Euro) - [2x151 @ 4ohm]
* Helix A4 Competition (27/30; 700 Euro) - [4x93 @ 4ohm]
* Helix A6 Competition (27/30; 700 Euro) - [6x88 @ 4ohm]
* DLS Ultimate A4 (27/30; 1250 Euro) - [4x84 @ 4ohm]
* Sinfoni Amplitude 120.4x (27/30; 1350 Euro) - [4x148 @ 4ohm]
* Soundstream Human Reign 2 (27/30; 4500 Euro) [2x501 @ 4ohm]
* lanzar Opti 500 XS (26/30; 900 Euro) - [2x456 @ 4ohm]
* rockford fosgate Power T 15004 (26/30; 1300 Euro) - [4x286 @ 4ohm]
* Zapco C2K-9.0XD (26/30; 1800 Euro) - [2x639 @ 4ohm]
* Helix B2 Precision (25/30; 380 Euro) - [2x138 @ 4ohm]
* DLS Ultimate A2 (25/30; 675 Euro) - [2x86 @ 4ohm]
* Helix B4 Precision (24/30; 400 euro) - [4x70 @ 4ohm]
* DLS Reference RA20 (24/30; 480 Euro) - [2x136 @ 4ohm]
* DLS Reference RA40 (24/30; 520 Euro) - [4x77 @ 4ohm]
matdotcom2000
matdotcom2000
Houston
matdotcom2000
