Ganglyminnow
Amp: RAA1000
Subs: Pioneer something or other...400wrms each
Each sub is wired negative to negative, positive to positive.
The subwoofers are then connected by two wires, each for a separate polarity; this was done so I only had to run wire from one terminal cup.
Finally two wires, one runnung from the (+) on one VC the other from the (-) of one VC are connected to the terminal cup on sub-box.
My question is this: AMP has two sets of +/- terminals; should I run the positive wire from box to the (+) on the first terminal and then the negative wire to the (-) one the second terminal? Would this achieve a 1ohm final load?
I ask this because right now ive got both positive and negative wires running from the box connected to the *same*(first) terminal and to be honest it is not 1000watts loud AT ALL - the mtx5500's or whatever running off 300w each were much louder?
Many thanks!
Many thanks!
