2 Dual 4-ohm Rockford Fosgate P3 12” shallow mount subwoofers
drockstar
Rockford Fosgate P3 12” shallow mount subwoofer delivers “Punch” even when depth is limited. The P3SD412 features Dual 4-Ohm voice coils for wiring flexibility and 400 Watts RMS power handling for the most demanding application.
Custom 10-AWG nickel plated push terminals
Reversable diamond cut cast aluminum trim ring
High excursion Poly-Ether-Ester surround
Kevlar Fiber reinforced semi-pressed paper cone and ABS/Acrylic dustcap
High-temp voice coil with spun-laced Nomex® re-inforcement collar
Extended pole piece and bumped vented backplate
Protective PVC textured magnet cover
Rigid die-cast aluminum low profile basket
Linear spider with embedded 16 AWG tinsel leads
Vented spider cavity
$160 + shipping
Like new in boxes:
drockstar
drockstar
Shreveport, La
Chin_Chilla
