2 Avalanche motors
Silver-N-Black
What's up guys looking for some advice here. Just bought 2 Avalanche motors they aren't here yet but they will be. Issue that I have and most of us have is limited space. This would be going into my daily which currently has 2-SA10's in a 4th order. I have around 3-4cuft tops, so below are the options.
Build them as 10's
Build them as 12's
or just build a single 15.
Avalanche 12:
Fs 23 Hz
Vas 80 Liters
Qms 4.36
Qes .39
Qts .358
Znom 4 ohms
Re 2.8 ohms
Mms 197 g
Sd 480 cm^2 - (74.4 sq.in)
Pnom 800 watts
Mounting Depth:
Gasket on - 6 9/16" (6.5625")
Gasket off - 6 11/16" (6.6875")
Avalanche 15:
Qts - .3
Qms - 3.5
Qes - .33
Vas - 300.6 Liters
Fs - 15.7 Hz
Re - 3.2 ohm
Le - 2.4 mH
Xmax - 27mm
800 Watts Rms
Sd 116.09 square inches.
Let me know what you guys would do.
It depends on the user's goals, but yes bigger = more xmax = more cone control = more sound. These are equipped with XBL^2 tech and have a coil that is maybe 1 1/4" long.
---------- Post added at 06:07 PM ---------- Previous post was at 06:06 PM ----------
how much power?
how much power?
thats not how it works.
bigger size doesn't equate to more xmax. Turn them into 10s. You obviously want good sound. I'd rather have all the room for a good designed box than trying to stuff 12s to "fit".
thats right.
and op thats what i would do also. turn them into 10" that way you can give them the right size box.
done right them 10's will slam and sound good.
Okay so i need a few more opinions. Last night i got in contact with Dave over at PSI. Looks like i'll be build a pair of 12's. Anyone recall how if this sub like big or small box? trying to search online but no luck.
Silver-N-Black
Silver-N-Black
SoCal
Silver-N-Black
