2 AQ 2200D Amp's Linked *Picz*
MasterOfAllBass
Team Minnesota's Loudest
Heres some pics. I got 2 fans blowing cool air into the amps though the vents on the sides of the amp. And works great. I can feel it come out the other side. I have 2 runs of 0 gauge from the front to the back. 180-200 amp alt, 2 redtops, Big 3 in 0 gauge.
more pics tomarrow. I tested it and its retarted loud.
FYI......the fans should be blowing down the heatsinks, preferrably on the former side where the power connections are...
Should be quite impressive with amount of power as I know mine do pretty well in a trunk car.
thanks for the info. Ill see how it works this way for a wile. I have all my setings all the way down for break in and its just as crazzy if 1 amp is on full tilt.
Those fans are overkill when you live in Minnesota haha. My amps get hotter off here in FL then yours ever will full tilt. Looks sweet though.
it gets to 100 here in mn in the summer. also the hummidy is 90% most of the time. But yesterday it was 100% and it sucked so much
Wow, thats surprising. Last time I was working on my system I had to use gloves when moving my amps, burned my hands when I tried to pick it up the first time. Black heat sink sitting in 130 degree trunk of a black car = HOT.
yea that sucks
Get as many batteries as you feel like getting. I'd get at least two more. That's a lot of power for a daily driver and if you're going to play at high volumes you'll need some juice for the amps:)
MasterOfAllBass
MasterOfAllBass
Minnesota
MasterOfAllBass
