2+ and 2- on hifonics monoblock?
Well there are 2 positive and 2 negative terminals on my hercules. Should i just use one of each, corresponding to each other?
I think it may be to strap, or hook another amp w/o running another set of + and - wires..........same w/ the rca's.
using a DMM, you can confirm that both + terminals are connected together, and both - terminals are connected. This aids in strapping (where applicable), as well as makes wiring of multiple woofer setups easier (think about setups that place a single woofer on each side of the car!).
They are the same terminal, it's so you don't have to cram 2 wires on one terminal.
It's a MONO amp. Think about it.
He's talking about the output terminals, not the Battery and ground.
Supergumby5000
Project: F350 begins...
Supergumby5000
Pullman, WA
jnralp00
