Isn't this always a problem with low qts subs? They need excessive power to play loudly.
Well if you don't have to give more power to the sub with the softer suspension to get the same SPL as the "SPL" driver' date=' then why do "SPL" drivers even exist? The hell's the point????
Isn't the goal to get as much SPL as possible with the least amount of power?[/quote']
Try giving a sub with an extremely soft suspension 5000 watts rms for a burp and see if the spider tears, coil bottoms out, etc. SPL subs use stiff suspensions for mechanical power handling.
So in SPL subs you want to aim for low MMS and high BL for efficiency, and also stiff spiders for mechanical power handling when dealing with extreme power levels.
Coil power handling is roughly 100W per layer multiplied by the diameter (in inches). This can vary of course, but a decent rule of thumb.Hey guys just need a little help understanding the differences between the two voice coil diameters. When I had 3" coils on my BTL the sub would require massive amounts of power to get moving. I was wondering if I stepped down to a sub with 2.5" coils would it require less power to get moving?
Thanks for your reply. I had my 15" BTL tuned at 35hz and once at 30hz and while it did get very loud, I knew it has more potential. But in my trunk car I believe 2 12's would move more air (not concerned with the numbers on the meter) while sounding better.What you are talking about is efficiency. The more efficient the sub is, the less power it needs for the same output to the point of distortion. I'm glad you are choosing this route over more power and less efficient subs. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
A SPL sub is designed to put out the most SPL at the specified tuning range or peak of the box and vehicle cabin. A stiff SPL sub will usually peak out a lot higher (55-65 hz range) than a sub that is designed more for SQL or SQ. For this reason, a stiff suspension SPL sub needs a heavy 3" or 4" coil and more power to overcome the restriction of the spider and surround (QTS).
I would rather take 2 efficient subs at 1500-2000 watts that can play flat from 20hz to 65hz than 1 inefficient sub with 2000-4000 watts that will peak around 55-65hz and not sound very good at any other range.
