2 15" SI Mags
What a dumb question. Describe the hypothetical enclosure specs, amplifier and its specs, and electrical system and people would be more equipped to answer that question.
A better question is are 15" SI Mags good drivers and can they sound great with the propper setup? The answer is yes.
My friend has 2 12' W6 in a cady, and it sounds like ***. So it is very unlikely that your 2 15's will sound good. The deville has a huge piece of metal between the rear seat and the trunk which makes sq nearly imposible to achieve.
Sawzall > Coupe deVille //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
I've seen it done, too. Nothing I have done personally. Although it does work in the cars I have heard...
If you're concerned about structural integrity, weld in some angle iron for bracing.
lol....even in the trunk I still have faith in the Mags that they'll make their presence known and sound quite good. if you want remove the back speakers to allow for some breathing room into the cabin....doesn't the caddy have a place for a 10in sub on the rear deck...take that out! but the mag 15s will sound good just depends if it'll make the impactful impression you want.
DatBoy420
I Got A Brick
DatBoy420
Pensacola,FL
k12ug
vegang
vegang
