2 15" Aq Hdc3 & Aq 2200
I double checked everything man, SSF is @ 25, and LPF is @ 100.
Call DJ
he'll give you step by step instructions on how to tune your whole system.
call the # on audioque.com //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yes, everything is strapped right, I even called DJ and had him walk me through it
did you play with any of the headunit settings so far? sorry if its been asked, i didnt feel like reading all the other pages.
and ****, if i still lived in Indiana, id be able to come help you out. which i may move back up there in a few years.
hmmm the only thing i can really think of is maybe the subs are wired at a higher impendence than 2. but im sure youve checked that with a dmm already..
are your batts keeping a good enough voltage for your amps?
they're wired at 2.2ohms (2ohms nominal)
checked voltage with a DMM, I don't drop below 13 without lights on, I slightly dim at night (barely noticeable)
177
383
480
  • Locked
768
Amp
559
jbizzle
jbizzle
Chicago, IL
jbizzle
