2 13TW5 or 2 Memphis S Class
I currently own 2 JL 13TW5's and a JL J2-1000.1 Amp. Should I try selling these and get 2 Memphis S classes and a Memphis Amp? I really just want to shake my car...I love the shaking, dont ask me why, but I also want some clear sound so you dont only hear booming if you know what I mean.
Would I have enough money to do it?
Please leave feedback, thanks!
id stick with what i already have broski, you seem really unsure of it without trying it first :p.. as we said it'll thump.. you can feel it and it'll be for the most part pretty dang clear. just try them out and see.
it doesn't work like that..
what voice coils are you your subs again? you could strap 2 of the same..amp if they are strappable or you have something like a hifonics maxxlink.
JL J2-1000.1 Amp
here are the specs for the subwoofers
Free Air Resonance (Fs): 27.52 Hz
Electrical “Q” (Qes): 0.511
Mechanical “Q” (Qms): 11.230
Total Speaker “Q” (Qts): 0.489
Equivalent Compliance (Vas): 2.10 cu. ft. / 59.47 liters
One-Way, Linear Excursion (Xmax)*: 0.383 in. / 9.7 mm
Reference Efficiency (no): 0.233%
Efficiency (1W/1m)**: 85.87 dB SPL
Effective Piston Area (Sd): 98.256 sq. in. / 0.0634 sq. m.
DC Resistance (Re): 2.793 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 600W
Driver Displacement: 0.052 cu. ft. / 1.47 liters
Net Weight: 18.6 lbs. / 8.4 kg
* Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
** Efficiency (1W/1m) is not an accurate indicator of a subwoofer's output capability and should not be used as a comparison to other subwoofers to determine which one is "louder".
*** Re (DC resistance) is measured with the voice coils in series, for parallel-wired specification divide Re by 4. All other specifications remain the same.
Bassin Brandon
Bay Area, CA
Bassin Brandon
