2 12's or 1 18
zeke813505
Iknow the 18 has more cone area but which would be louder considering motor force. I have 2 12" FI btls (fully loaded) but looking into a solo x or something along those SPL lines. Will not be used for competition. Only daily. They will be going in a 4 door f150. I took the whole backseat out for my audio. . Subs will be in correct enclosure and power . Or has a 18 they would trade for the FI btls and cash.
That 18 would need HUGE box if it was to be the proper size. I guess 2 12s need a good sized box also... but personally, I'd stick with the two 12s. Dont ask why.. I have no reasons to back myself up.
considering its fi btl 12's compared to say.. a single i btl 18.. thats double the power you could put on them if you had two twelves instead of 1 18".. i would think 4k would probably get a lot louder than 2k even taking in the fact it has less cone area..
I use to have a 18" FI SP4 and switched to my current setup of two Sundown SA 12". Power was identical and the difference in SPL was negligible, however I saved a lot of room going to two 12". The 12's are in a 4cf enclosure, where as the 18" was in a 8cf enclosure. If space is a concern, go with the 12's, if not I'd go with the 18" for the wow factor //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
just keep the 12s. if this was a burp only setup, id say 18, because single woofers are easier to reach the limits with for a given power class. but just stick with the btls.
zeke813505
zeke813505
San Antonio,TX
vetkilr
    May 18, 2024
    May 18, 2024
