2 12's 120.3 Kappa Perfect question
cstek
I am new to this and I am really trying to research I got both of those subs and a box for 128. I need an amp to power them, I need ideas? I have no clue what is good for amps out there. Im not looking to spend tons of money on a class D amp or anything, but I want to make sure I am powering them right at the 150 RMS per channel and wire them correctly for long lasting and best sound and loudness thanks.
I had that sub awhile ago, and it isn't a bad sub at all, especially if you are new. I believe they can take at least 250watts each, but you probably won't need that much. you should be able to find an amp that puts out 350-500watts rms pretty inexpensively. Are your subs Dual or single voice coil? What is your budget?
They are Dual Voice coil and I believe they are 150 RMS @ 4 ohms per VC or 300 rms per sub @ 4 ohms. 200 bucks and under would be nice for the amp, I know I dont want a sony.
all you need is about 500-600w at 4ohm or 1ohm. 1ohm would mean you wire each speaker in parallel and then wire the two speakers in parallel.
http://cgi.ebay.com/CADENCE-750w-RMS-1-OHM-MONO-COMPETITION-CAR-SUB-AMP_W0QQitemZ300278803144QQcmdZViewItemQQptZCar_Amplifiers?hash=item300278803144&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
that is an option, but there are much cheaper options. just look for something that has the power you are looking for, and is 1ohm stable.
Is that a really good amp? It has the subsonic filter and all that, that would almost be perfect. I likely will buy that one. Another question though, when I wire them at parallel and play them at 1 ohm, is that louder or any clearer as opposed to 4 ohms?
cstek
cstek
Saint Louis
cstek
