2 12" JL W3v2's vs. 2 12" RE SE
i am very aware of where the SQ goes away...
when i had my little bout with these audiobahns i
"tried" in my car i turned my gain up on my amp
to support the extra [farting] power of the
audiobombs...
now... when i put my JL's back in i just eyeballed
the gain back down... well... i didnt turn it down
enough and the JL's just would give these
quick aggressive bumps... all the smoothness
was gone... it didnt sound good or powerful...
i spent a good hour driving and fiddling with
the gain to get it back where i wanted it... now
they sound great again... but i do have them
pushed one tiny smidge too far... so in some
instances the low SQ comes back...
its all trade offs... but these subs are set...
you sound like a bigger fan of the W7 than the W3's...
i realize that the W7 is obviously much better... but did
you have a bad experience with your W3's???
W3's were great for my setup with 2 subs but when I went down to one sub I needed a more powerful sub. I had 500 watts going to the two W3's which could handle 600 continous together, so then I wanted more trunk space and went with a single RE SE 12. I really should have just stuck with my single 10W7 since I have pretty much come full circle. W3's are great but you would need 3 or 4 W3's to compete with 2 Re SE's assuming your current amp situation. I'd rather have one or two subs with more watts going to them than less wattage and a trunk of subs.
Add another 12W3 and your setup would rock if you want to make a new box and lose even more trunk space.
someone else suggested the third JL... but i dont
want three subs back there... thats too much...
2 12"s fit nicely...
plus since the RE SE's perform better in an even
smaller box than the JL's i wouldnt have to worry
about losing space if i decided to keep with the
sealed box...
it was a good suggestion...
with this amp would i actually be
hooking the speakers together
with any more than 2???
my box has each chamber sealed
so how does that work??? not that
im going to go with the 3... just
curious...
well... cause my amp has 2 + and 2 - speaker outs...
so i have each sub wired to the amp using all the outs...
so if i wanted more than 2 subs wouldnt i have
to connect the voice coils of one sub to the
voice coils of another sub... like a chain to the
amp...
my amp recommends no more than 8 subs... i assumed
you would have to wire the subs together to pull that
off...
as far as the sealed thing... if i were to have to wire
the subs together i would have to put a hole in the
inside divider of the box to run the wire???
The two outlets on the amp are internally wired together so they essentially the same outputs. It just gives you a place to run another set of wires for another speaker like you did before. You would wire it with one set of wires to one sub and the other set to the other sub. I assume that you have to wire inputs on the back of the box, one for each sub. On the subs you would wire them in parallel.....hook both positives together and both negatives. Look at the second diagram that says "parallel/parallel" . You can do it exactly like the diagram or you can use both outputs on the amp.
http://jlaudio.com/tutorials/dvc/point.html
i have each sub now wired
+ to + for the voice coils to the + terminal on the box
- to - for the voice coils to the - terminal on the box...
the amp looks like this
i am using all four connections... the amps manual says
that to bridge it for one sub you only use the
first positive and last negative...
my question was more about getting more than two
subs... but i suppose it would be just like in the
diagram... where as i dont have it exactly like
the diagram because i can use all the outs on my
amp to run just the 2 subs...
i was just thinking that wiring the subs together
would be weird getting the physical wire from one
speakers voice coil the the next without creating
a hole in the box...
OK, then your amp would be bridged and you would use just one + and just one - on the amp and running two subs would look exactly like the diagram link on my previous post.
To wire several subs within the same box with seperate chambers you could do it on the outside of the box with the wire terminals (red/black) or cut a hole in the divider of the chambers and then run the wires through and seal it with caulk or a glue gun. But as you can see in the diagrams on this link as long as you have the wire terminals on the outside of the box, one per sub, you would never need to cut any holes in any dividers.
http://jlaudio.com/tutorials/wiring/index.html
that explains it perfectly... thanks!!!!!!!!
//content.invisioncic.com/y282845/emoticons/coolflash.gif.4f9740e1268764cfe452b9259e375e3b.gif//content.invisioncic.com/y282845/emoticons/wave.gif.002382ce7d7c19757ab945cc69819de1.gif//content.invisioncic.com/y282845/emoticons/peace.gif.2db28b618ed8d1964ebbe2f5021d2c39.gif//content.invisioncic.com/y282845/emoticons/thumbsupwink.gif.129404938effda6ad9cca39e7f4b58a3.gif//content.invisioncic.com/y282845/emoticons/needpics.gif.edd6d28e76618c28c46f343991bcced5.gif
too much fun...
g30ffr3y
soul destroyer
g30ffr3y
buffalo, ny
g30ffr3y
