Sold 2 12" Alpine Type R's
Sleeklsc
EDIT: 180 shipped !!!!!!!!now!!!!now!!!!....
ebay
http://cgi.ebay.com/Alpine-Type-R-12-Subwoofer-SWR-1222d-dual-2-ohm-N-R_W0QQitemZ200016519321QQihZ010QQcategoryZ18803QQrdZ1QQcmdZViewItem
Dual 2 ohm
They work 10/10, the only problem with 1 of the woofers is cosmetic and does not effect performance. The cosmetic imperfection is located on the metal magnet cover and it has roughly a 2.5" crack thats barely noticable. other then that they are just abit dusty.. 500rms/1500 peak
Frequency Response: 24Hz - 500Hz
Kevlar Reinforced Pulp Cone
High Excursion ¾" Santoprene® Surround
Dual Voice Coil
Custom Cast Aluminum Frame
Integrated Leg Vent System
Bumped Backplate
Heat Transfer Plate
High Strength Brass Voice Coil Bobbin
Double Stacked Magnets
Oversized Parabolic Dustcap
Magnetically Optimized Motor Structure
Designed and Engineered in the USA
Peak Power Handling 1500Watts
RMS Power Range 500Watts
Impedance ( Ohms ) 2
Free-Air No
Dual Voice Coil Yes
Sensitivity 87dB
Frequency Response 30-500Hz
Cone Material Kevlar Reinforced Pulp
Surround Material Rubber
Dimensions
Sealed Box Volume (cu ft 0.5-0.8
Ported Box Volume (cu ft) 0.6-1.25
Top Mount Depth 5-15/16"
Cutout Diameter or Length 6-7/16"
Size 12"
price is set at 175+ shipping for the pair..i will entertain all offers
i looked at the crack and its not as bad as i thought..i couldn't even manage to get a good shot...if you look closely you can see a little black thing, its right there..
Sleeklsc
Sleeklsc
gc86
