2 12 L7s and 2400DB
power acustic amps are a lot of watts for a cheap price and thats because the amps usually wont produce but about half of the watts it says it will..go with a memphis amp..it will cost more but i promise you will be a lot happier and it will be a lot louder..a 1500 watt memphis amp is your best bet (memphis amp will usually push more watts than it says so it would closer to a 1700 watt amp)
Power Acoustik amps are fine. Usually overrated by 2-300 wrms, but totally fine. If you're thinking Power Acoustik go ahead and get the 3000db. Are these 06 model? If so, give em 1000-1200 wrms, if 04 then 600-900
hey hey big pimpin,word nucka word, foe shezzy. " edit " IMO just stick with the 2400bd if you do not want to upgrade your electrical system right away,,, it would be benificial to atleast to the big 3. I think the 2400 would be plenty for 2 12" l7's it will most likely put out around 1800-2000 watts wired / tuned correctly....
Oh aight, the Subs I got are Dual 2 ohms so i'll wire them at 2 ohms, and its rated at 1400 watts rms when wired in that series. But just get a big 3 to be safe??? I have a brand new car, 06 for fusion
Yeah, I'm just trynna Put Some of dat King Kong In my Trunk man, and How many watts rms you getting outta that USAmps MD2??? Wiring it At 2 Ohms or 1??? If 1 then you must have dual 4ohm subs
bigmarv89
"The One"
bigmarv89
Atlanta
bigmarv89
NorthFramingham
    Jun 30, 2026
