1st time builder here
pbnj22
ok so after me being an idiot i have now to build a box for my 12 inch diamond audio d9 d2, running of a autotek 1900.1 (800 @4 im running), would like sealed or ported leaning toward sealed for now.
could someone give me some help or input or something
what dimensions should a use? i have mdf wood and glue and screws for now
anything else i need?
Corner braces help a lot if you're building it by yourself and silicone to seal the box when it's done. How are you planning on cutting the MDF? A table saw is preferable.
Also, search! This has been covered many, many times.
i plan on using a table saw as you mentioned
1 ohm is asking for trouble isnt it? it will last longer most likely blow my sub what about 2 ohm for a happy medium 1500 watts sounds nice doesnt it
It's not if the amplifier is built well and stable down to 1 ohm. You can only run it at what the voice coils are configured at. What is the VC configuration?
Also, check out the stickies at the top of the section you posted your thread in. There's some helpful info there for box design. Although there isn't one for box building, which is dumb. Google that and you'll get some pretty thorough walkthroughs and videos.
You don't have to send it all that power. Just get a 50 hz test tone and a dmm and set the gains to 44.7 volts which is 1000 watts.
yeah his sub is d2 i think, thats why i said 1 ohm load, and plus, getting 800 rms @ 4 ohms w/o clipping the shet out the amp would be hard. and im sure the sub can take more then 800 ( so he will keep turing the "volume" (gain) ) up till his amp clips.
thanks...will look into that, if i do a sealed box can i just pretty much wing it cut out a rectanular prism thing and cut i hole for the sub?
pbnj22
pbnj22
Duluth MN
mgbcs
