1990 Buick Reatta
i have a 93 regal and i'm sure you have the same stock h/u. does yours have the tuner part up by the climate controls and the tape down from that?
you are gonna need a bracket to mount it under your dash or take out the tape deck and install there. i honestly recommend going to a shop, even be a CC, and getting them to do it if you aren't sure, it is a PITA
go ahead and get a deck at a shop, usually if it's over a hundred bucks they will do the install for just the cost of the dashkit, honestly, if you uninstall and remove the stock h/u you will have a ton of room for a indash. that is what i'm thinking hard about, just need to find someone in the NW i can trust enough to do it.
Yeah there are no dashkits available for the car as far as I know, but I should be able to run a CD changer from the trunk and slave the CD player shouldn't I? I'll probably let Best Buy mess with the installation though.
Does it have the digital a/c and all that crap?
My dad had a 91 riveria which is basically a reatta.
I installed some speakers in the back, they didnt fit.
I installed a power antenna in it, it didnt fit.
I tried to upgrade the front speakers, door panels were a pain to come off so i didnt bother
96civ
96civ
Indianapolis, IN
supa_c
